Is there any good place to stick an amp?
Old May 22, 2003 | 01:38 AM
1COOLPC's Avatar
Car is a 2002 Z28. I'm running a good size amplifier, an Alpine MRV-F450 17" x 11" x 2.5" Is there some place I may be overlooking? I have a CD changer but it wouldn't fit there any way and I'm not willing to give up my spare because I travel. Suggestions? The only place I can see is against the rear wall of the t-top cargo compartment but I was hoping for 100% stealth. I'm probably out of luck but just in case I'm overlooking something I thought I would ask. Thanks.
Old May 22, 2003 | 01:52 PM
slayer6x6's Avatar
i dont know about the 4th gens, but in my car, which is a 3rd gen, the amp is mounted in the rear storage compartment on the opposite side of the spare.
slayer6x6's Avatar
Old May 23, 2003 | 02:26 AM
PaulN64's Avatar
you might want to install it in the trunk on the side of the gas tank, flush againts the panel facing the gas tank. I think there's enough room there for the amp and the ttop to fit at the same time.
Old May 23, 2003 | 07:05 AM
97FormulaWS-6's Avatar
I've got 5% on my rear window..... so both of my amps which are LARGE are mounted on custom brackets on the deck. You can see just a slight shimmer of the one chrome amp when the sun is shining directly on the hatch, otherwise it's invisible.
Plus they're all mounted with Tamper-Proof Torx bits.... so whoever wants to remove them is going to have a really really really fun time...
Old May 23, 2003 | 03:29 PM
slayer6x6's Avatar
not a bad idea, ill have to try that
marineengineer
Feb 9, 2015 03:59 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
NewsBot
Jan 8, 2015 11:29 PM
