where to buy a "seat to rollcage" brace ?
Old May 21, 2003 | 12:06 PM
sideways_Into_3rd's Avatar
all aftermarket seats require to be braced against the cage and i heard u can buy these online and mount them on ur cage and their adjustable etc etc...
does anyone know where to get one ?
Old May 21, 2003 | 12:40 PM
CSJTA's Avatar
I know Jegs sells them, there's two different kinds, depending on what seat you are using, part numbers are 550-40485 and 550-40486. HTH.
Old May 21, 2003 | 12:54 PM
thanx for that link
but i doubt those would work with my corbeau CR1 seats ..
maybe i'll get something custom built locally unless someone else has some other alternatives !! thanx
Old May 21, 2003 | 08:28 PM
Stephen 87 IROC's Avatar
I welded a bracket to the cross bar that fits up against the back of the seat. I drilled a hole through the front part of the seat for access and bolted the rear part to the bracket with a 1/2" bolt. The seat cover hides the hole and it passes tech. I've seen some fancy seat braces that are adjustable so that you can adjust the seat.
92_RS_305
Apr 19, 2015 01:45 PM
jbrockwell
Mar 14, 2015 08:44 PM
Jan 23, 2015 01:13 PM
Joes96z
Dec 14, 2014 04:03 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
