Bolt-on stuff
Old May 15, 2003 | 07:39 PM
Knowklew's Avatar
Bolt-on stuff
How long does it take to bolt on the SLP Loudmouth and the SLP y-pipe? And also how long will it take to install the flow pac from SLP?
Old May 16, 2003 | 12:33 AM
stik6shift98's Avatar
no more then 2 hours
Old May 16, 2003 | 02:02 PM
mattbaer's Avatar
Just had the SLP Loudmouth installed on wed night. It took just over 1hr.
Old May 17, 2003 | 12:32 PM
BlueNWhiteTA's Avatar
It should not take more than 2 hours. HOWEVER, Note: SLP will include directions on installation. If you do not want to cut the stock exhaust off, and would rather remove it as a whole, DO NOT FOLLOW THEIR DIRECTIONS! You can't drop the rear axle enough to bring the exhaust over it unless you are on a lift. I tried it on jackstands and it ended up taking me around 5 hours because I had to remove the clamps, remove the panhard bar, shocks, and lower the suspension, and then I realized it wouldn't come out, so I had to bolt EVERYTHING back together and cut the exhaust off anyway. So much for keeping the stock parts....I destroyed the piping with a hack saw
revrider
Cars Wanted
Apr 5, 2016 10:06 AM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
cmsmith
Sep 14, 2015 09:09 PM
jackpawt883
Sep 10, 2015 08:53 PM
WPHIG2
Aug 27, 2015 06:37 AM
