trans & clutch are out again! also cylinder head is off, all in a days work :)
From: Windsor, Canada: Home of the FASTEST LT1 & LS1 6 spds :)
what a busy day, threw my car on stands and yanked the trans and clutch, Thanks Roman!
then went over to a friends house to pull a cylinder head! whew!
all done, now to send the clutch back to Mcleod for a refreshening, spoke to George there and i know he is going to set me up just fine, sorry guys but i'll never go auto! ha ha ha!!!!!!!
MY car featured:
www.bmrfabrication.com.htm
1996 Camaro SS A.R.E 398
11.36@120.35mph, NA
10.14@135.11mph N2O(no more excuses
Best 60' 1.375
Best mph: 135.11mph
oh yeah also an 80 Camaro, an 98 Ram Sport, the latest addition a 94Z28, w/T-Tops!
"...i wish i was the full moon shining off a Camaro's hood..."
P.J.
MY car featured:
11.36@120.35mph, NA
) Best 60' 1.375
Best mph: 135.11mph
P.J.
I'm about ready to pull my trans out and have it worked over. I believe I bent the 3/4 shift fork pretty good. I'll rework the master and slave while I'm at it!
Grand Rapids, MI
2002 WS6
http://www.sigma-epsilon.org/steve
stevedertien@attbi.com
Whisper Lid, Grotyohann Headers and Y-pipe, Corsa Exhaust, BMR SFC's, McLeod Single Disk, Spohn Torque Arm, LCA and Panhard Rod and much more to come
Grand Rapids, MI
2002 WS6
ouch! i hope you only bent the shift fork and didn't break it. i guess if they break you can kiss the trans internals goodbye, or so i have heard from the folks at D&D.
I hope you aren't driving the car like that. throw the viper shift fork in there you should be all set then.
i had my gears, input shaft, output shaft and cluster all cryogenically frozen. it can't hurt.
MY car featured:
11.36@120.35mph, NA
Best 60' 1.375
Best mph: 135.11mph
P.J.
MY car featured:
11.36@120.35mph, NA
) Best 60' 1.375
Best mph: 135.11mph
P.J.
<font face="Verdana, Arial" size="2">Originally posted by taner:
</font>
</font>
well the time has come, the stock clutch just isnt up to the duties anymore. I know I am not a "big dawg" and I am not making huge power buy why mess around. McLeod is gonna be the way to go. Where can I score a good deal on one?
Matt Bonventre
Motown Muscle Officer
www.motownmuscle.com
1997 Z28 Drop Top M6
STILL bolt ons
STILL stock long block
STILL stock suspension and gears
13.048@106.39
12.145@113.54 w/ 100 shot of the juice
Matt Bonventre
STILL bolt ons
13.048@106.39
From: windsor,ontario,canada Home of the fastest LS1 and LT1 6-speeds :D
Taner, no problem, anytime you need some help and I can, I will be happy too. Thank you for helping me too.
derty, sorry to hear about the tranny. D&D seems to be the best place to get all of your t56 stuff done at.
Matt, you definately will not be disappointed with the street twin.
I ended up getting most of my stuff from Barry over at Quick Time Performance or Thunder Racing. You really can't go wrong with either one, just make sure you replace your slave while you are at it (you'll be sorry if you didn't). And becareful as to what brake fluid you use, the seals are tempermental against some synthetics or basically anything that's not mineral based. Long story on that one!!
DERTY,
just wondering about the slave, the one on my car only has 3000 miles on it. it is a new factory unit, i have never had an issue shifting into reverse which is a sign that the slave isn't able to perform adequately, i imagine that with a stock clutch i would be just fine, however with the street twin things are a bit more difficult.
Roman,
my pleasure, yet again a learning aexperience
Matt,
i know of someone with the same clutch i have for a very cheap price, only 150 or so miles on it and maybe 12 passes` email me and i can send u his ph. #.
one thing i have learned from mcleod is that this clutch is notthe type to be slipped, avoid it as much as possible. it may make for a harsher ride but if the clutch lasts then it is worth it in my opinion.
well gotta get crackin @ work
MY car featured:
11.36@120.35mph, NA
Best 60' 1.375
Best mph: 135.11mph
P.J.
Roman,
Matt,
MY car featured:
11.36@120.35mph, NA
) Best 60' 1.375
Best mph: 135.11mph
P.J.
Taner,
I talked to McLeod about this with my car. Basically what happens to the slave is that the seals get used to a certain pressure. When you change the clutch (especially with a higher pressure) those seals are immediately disturbed.
My car had about 15,000 miles on it when I changed my clutch to a single disk. My slave immediately started to spew fluid when we were bleeding it because of the pressure difference! Prior to the install the slave was fine. It's only a $60 part from GMPartsDirect.com and it's just some added insurance and includes the new throwout bearing on it.
About the brake fluid you use. I've also learned that any fluid that is not mineral based risks the chance of eating the polybutyl rubber seals in the McLeod master and possibly the slave. Over time the seal seeps and you end up with some variable pedal pressure. I ended up with this symptom after using Valvoline Syntec Dot 3/4 which is a synthetic fluid. The pedal was great for 3000 miles or so and then bang went to hell quickly. I'm rebuilding mine now that I need to get the tranny out. I'm going to use ATE Super Blue fluid instead. It's got a really high boiling point and it's mineral based which shouldn't eat the seals up.
The clutch still works with the fluid issue, it just sucks to have an inconsistent pedal. Engagement zone remains the same though, just that the zone moves up and down the pedal range. McLeod sells a rebuild kit that contains the new cup and o-ring in case you have to rebuild your master. Much cheaper than buying a new one!
Hope that helps!
Hope that helps!
derty,
since that gm clutch master/slave has only seen the mcleod, will i be ok? i just sent it out this morning to mcleod, and it wasn't cheap!
HInk,
street car....street car!
i don't want to have to bang gears everywhere i go, lmao @ HInk!!!!
aka: Luke Stickshifter......
HInk,
derty,
</font>
derty,
</font>
Just make sure that if it does go bad to get it off the road quickly. Brake fluid on the clutch will destroy it and you'd be buying another clutch!
well i haven't noticed any fluid loss and the fluid level is full in the master resevoir, so i think that is not an issue.
pedal felt a bit softer but that has to be because the clutch had just gone away it was very well worn.
pedal felt a bit softer but that has to be because the clutch had just gone away it was very well worn.</font>
