NOS MPFI NOSZLE kit??
Old May 10, 2003 | 01:17 AM
TCAL95Z's Avatar
Is anyone using the NOS NOSZLE kit?
If you are where is the best place to buy it? both summit & jegs can't give me much info except a price.
This kit looks great. Why is no one talking about it?
Old May 10, 2003 | 06:27 AM
RacinLT1's Avatar
not many people are using it,not sure if it is due to the price,or the difficulty in using it with the LT1 intake.
The biggest issue with 94-97 LT1's would be the crossover tubes that would have to be shortened or reoved and replaced with braided hose.
Old May 10, 2003 | 08:16 AM
TCAL95Z's Avatar
are you talking about the cross over tubes on the fuel rail?
Why do they have to be shortened or removed?
I priced this kit at around $1500 with a polished bottle which is about the same price as a maf kit with a carbon fiber bottle and the genx2 upgrade. The only problem I see is price because it doesn't come with a bottle heater, blow down tube or purge but I don't think you would need a purge.
Thanks
Tom
Old May 10, 2003 | 11:40 PM
RacinLT1's Avatar
look at the angle of the fuel rails. they are not stright up and down,that tilt in towards the middle. raise them a 1/2" and they will want to come closer towards the middle,and the balance/xover tubes wont let that happen.
Old May 11, 2003 | 02:10 AM
TCAL95Z's Avatar
ok, I see what you mean. So what would you do cut the cross over tubes and put in a flexible fuel line? Or have a different fuel rail made?
Old May 12, 2003 | 12:07 PM
snow2000SS's Avatar
You could do it if you use after market fuel rails. I've seen it done with the holley fuel rails. It's still not easy but it is possible.
lt1xondeck
Mar 18, 2016 07:22 PM
95z28man7
N2O Tech
Aug 16, 2015 10:58 AM
LeftoverChinese
Jul 23, 2015 03:57 PM
Jlo
Jul 22, 2015 05:00 PM
colts0455
Jul 20, 2015 09:52 AM
