can u turbocharge a 305 TPI???
Old May 2, 2003 | 02:46 PM
Dr. Z28's Avatar
Question can u turbocharge a 305 TPI???
im sure u can turbocharge a 305 TPI im just not surew where or how much it would cost... i need a reasonable set up just to get a good time i was think a TA-60 i think it is would be a great size for this engine... i dont know i need some tips. if u guyz know any1 around tampa,FL plza let me know.. thnx i hope some1 knows..
Mike
Old May 2, 2003 | 06:22 PM
Teknohund's Avatar
I would say dont do it. The TPI is very restrictive on anything above 5k rpms, and if you turbocharge it, it would only magnify it. Now if you put on a different intake..........
Chris
Old May 2, 2003 | 06:35 PM
doug791's Avatar
theres no point in a turbo if your engine is pretty much stock...with a stock 305 (im about to put out a random number that could be way off) you could run a turbo with a max of like 6-8 pounds of boost? and for the money you could beat the amount of hp you would get from the turbo with other mods. The idea is usually to build up the entire engine with good parts and then get a turbo because you can run an insane like 25 pound boost through your turbo and get a 250-300 hp increase
Old May 2, 2003 | 07:12 PM
SilentBob's Avatar
On a built engine, I would hope you would get more than 300hp on 25psi.
SB
Old May 2, 2003 | 07:19 PM
Irocvette355's Avatar
http://www.skulte.com
Old May 2, 2003 | 09:38 PM
doug791's Avatar
really? i had been told by a buddy of mine that he gets about 300 horses out of that much boost on his grand national engine but i know he doesnt know that for a fact theyre just vague numbers
Old May 2, 2003 | 09:48 PM
EyE_RawK_ZeeE's Avatar
how much exactly would a 25 lb setup set a person back?
-J-
Old May 3, 2003 | 12:25 PM
DarthIROC's Avatar
A crapload of $. IMO opinion with your engine if you want forced induction go with a supercharger. You will acheive pretty much the same result. With much less headaches and $ spent.
And as a side not esince you asked, I know Im not the Forced Induction expert you were lookig for but I do live in Tampa.
Old May 3, 2003 | 12:41 PM
AutoRoc's Avatar
dyjdgyf
Information and research.
If you aren't sure if an engine "can" be turbocharged, then you honestly shouldn't pursue the challenge. Read some books, surf the web for personal experiences, and do some calculating.
Andris Skulte's website is a great way to learn about how this can be done. The man is a great engineering mind. Goodluck!
Old May 3, 2003 | 09:36 PM
Zepher's Avatar
Go read the book "Maximum Boost" by Corky Bell
Old May 4, 2003 | 02:03 PM
fly89gta's Avatar
if he's only getting 300hp on 25#'s even on the stock turbo he's doing something very,VERY VERY wrong or he's totally underestimating his numbers..
Old May 6, 2003 | 12:26 PM
ws6transam's Avatar
Hi there!
There's no reason why you cannot turbocharge a 305, any more than turbocharging a 350. Both engines use a 3.48 inch stroke crankshaft with the same size main bearing journals. Both use 5.7 inch rods with the same composition. Both use pistons of similar construction and quality. Reliability of a 305 is on par with a stock 350 in most every way.
The 305, by virtue of its smaller bore, has a harder time filling the cylinder with air/fuel during the intake phase. A turbo can help overcome this issue by increasing the density. So can supercharging and nitrous. This may be why some of out 305 owners are getting some unexpected increased efficiency out of their nitrous kits when at the track... (hint..hint..DennyV ! )
If you have an LG4 version of the 305, you already have an engine with 8.5:1 compression ratio which is also a decent starting place for turbocharging. The places you need to first look for efficiency and changes are not at the intake side, but at the exhaust side, and at the camshaft. Your turbo application will necessitate a custom exhaust, but while you are working it over, be sure to get in and port out the exhaust in the cylinder head. You will need to clear out the restrictive port so that you can more efficiently apply power to the vanes of that turbo. The boost on the intake side will go a long way towards getting the air through the restrictive intake tract.
On cams, the trick seems to be a profile with a wide lobe separation angle, and a big exhaust duration. Of course, again I defer to our turbo expert Andris Skulte. http://www.skulte.com
You will need to also increase fuel delivery via bigger injectors ( 30 lb. / hr), ECM tuning, and will also need to fix your cooling system with an aftermarket radiator by Griffen or Be-Cool.
That's my two cents on the matter. If you want to turbocharge, definitey start with your current engine. You can afford to make mistakes on it. It sure would be a shame to spend $3800 or more on a killer new longblock, just to have your newly designed fuel delivery system go lean and burn holes in your new pistons on the maiden voyage.
--drb
G-BODYT56
Jan 14, 2022 11:14 PM
Tarizza
Sep 20, 2015 03:26 PM
gonzo275rltw
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
