how do you remove the IAC sensor?
Old Apr 14, 2003 | 11:38 PM
saiyanrage's Avatar
Question how do you remove the IAC sensor?
I'm replacing the single snorkel with a open element.I had to disconnect the IAC to remove the old base.Now I can't figure out how to remove the IAC sensor from the old base.It doent look screwed or plugged in.I'm afraid to pull too hard because I dont want to break it.How's it come off?
Old Apr 15, 2003 | 08:33 AM
Jim85IROC's Avatar
It's screwed in, which is why the case is a big hex shape. I think it needs a 1" or larger wrench.
FWIW, an open element on a TPI car looks good, but you'll lose power. You're going to be sucking in some very hot air.
Old Apr 16, 2003 | 10:36 AM
aklim's Avatar
It is screwed in. You will need to replace the gaskets tho. There is one there and one between the cover and the TB. Why are you doing that if all you are doing is an open element?
Old Apr 16, 2003 | 02:10 PM
saiyanrage's Avatar
I was following these instructions http://web.ics.purdue.edu/~mforma/ol...penelement.htm
opps just noticed it was a iaT and not a iaC. My bad. Anyway I finally got whatever it is off by prying it off with needlenose.I got it off in one piece and rehooked it to its harness ans pushed it back toward the firewall.The instuctions said use a 3/4 socket and I was also told a 1 inch.Neither worked and thats where I got fustrated at.
Thanks for answering guys!
Old Apr 17, 2003 | 01:51 AM
aklim's Avatar
Next time state what engine you are working on. I was assuming it was a TPI but it obviously was not
Old Apr 17, 2003 | 07:17 AM
Jim85IROC's Avatar
I did the same thing.
Old Apr 17, 2003 | 09:13 AM
saiyanrage's Avatar
Sorry guys..I forgot to add the part about it being a LO3.My mistake.
Thanks for replying and trying to help anyway.
HectorM52
Jul 30, 2017 11:46 AM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
BigWil
Mar 29, 2015 12:24 PM
lt1matt
Mar 21, 2015 07:35 PM
Queens94z28
Dec 20, 2014 09:11 PM
