Helpp!!! I Need Pcm Tuning For 96 Z In Nj A.s.a.p.
Old Apr 6, 2003 | 01:23 PM
Ncam85's Avatar
I just had the cats removed and a set of O2 sims installed. The car just gets a ses light and stumbles all over the place. I reset the computer and drove it for 45 minutes with little change and the car won't hold an idle.
I have a SLP CAI, LT4 KM, Grantelli MAF, 52mm BBK TB, MSD Ignition, MSD wires and new plugs and a single 3" exhaust.
I can spend up to $400 or so. Just want to get it to run right or I will be looking for another stock y-pipe to get it back to normal.
thanks
Nick
Old Apr 6, 2003 | 03:12 PM
madwolf's Avatar
Although I'd recommend an OBDI conversion , it sounds like your problem may be something else. Get the car scanned at a place like AutoZone (they do it for free) and see what codes you're getting first.
Old Apr 6, 2003 | 03:15 PM
Ncam85's Avatar
I was just under the car myself this time and noticed a 3rd o2 sensor in the middle of the y pipe with a square 4 prong plug.????? I am not sure if this is the problem or what
I thought there were only 2 o2 sensors on the car???
Thanks,
Nick
Old Apr 6, 2003 | 03:16 PM
madwolf's Avatar
Oh uh... did you install the sims on the front o2s??
There's 4 sensors on your car. If you got rid of the cats, you need to install the sims on the rear 2 ones.
Old Apr 6, 2003 | 03:18 PM
Ncam85's Avatar
the rear sensor has a different plug that the front so I guess they are the wrong sensors
I ordered them from year one parts.
they sent me the kit for 2 sensors for a 96 LT1
Old Apr 6, 2003 | 03:28 PM
madwolf's Avatar
You can get rid of the o2 sensors through programming as well. I sent you a private message...
DSMKilla
May 26, 2015 10:10 PM
thenewkid
Apr 12, 2015 07:42 PM
chuyz28
Apr 9, 2015 09:36 PM
Bignasty85
Mar 3, 2015 04:05 PM
nikolt1
Feb 27, 2015 09:10 PM
