VE tables and increasing displacement
Old Apr 3, 2003 | 02:26 AM
96z's Avatar
96z
Ive been looking through a bunch of OBDI files and OBDII files and it seems that some people like to mess with the VE tables and some dont....Is this related to the fact that some like to change the cylinder volume when increasing displacement and some dont?
Old Apr 3, 2003 | 11:29 AM
Grover's Avatar
This has been a heated discussion on the LT-1 Edit mailing list and the general concensus is that the VE tables are only used in speed density mode. Some people will tune the car in MAF mode until it's where they want it and then tune the VE tables in SD mode until it runs about the same that way they are safe if the MAF ever dies.
Old Apr 3, 2003 | 12:15 PM
96z's Avatar
96z
Interesting...thanks. Where in the program can the increased displacement be made up at if the cylinder volume isnt changed?
Old Apr 3, 2003 | 06:11 PM
Grover's Avatar
I don't have my LT-1 Edit handy, but there is a box on the same page as the injector constant that has engine size in cubic inches available to change.
Old Apr 9, 2003 | 10:21 PM
RicocheT's Avatar
Is this only on Lt-1 edit? The engine displacement box that is? I'm trying to figure out what program to get before i do any tuning, I will be new at it but not new and messing with motors.. Reason I ask is if i get tuner cat (cheap) I will need to change the displacement for one of the cars I mess with.
96z where are you looking through files? I'd like to see a couple before i start trying to tune any. Thanks in adv!
Old Apr 9, 2003 | 11:39 PM
JSK333's Avatar
TunerCat has the ability to change the cylinder volume too. It's listed in mL. I think stock is around 717 or so.
This is completely separate from VE tables. It would just be a coincidence that those with strokers tune VE tables, in my opinion.
Old Apr 10, 2003 | 01:25 AM
96z's Avatar
96z
So is it better to leave the VE tables stock and change the displacement, or leave the displacement stock and change the VE tables?
Old Apr 10, 2003 | 10:20 AM
JSK333's Avatar
IMO, it's not an "either or". Definitely change the cylinder volume value if yours is different than stock!
Then, if you're running speed denisty mode, tweak the VE tables, starting with VEmaster, then by hand.
Bigtoyz97
Sep 21, 2015 01:44 PM
Aug 24, 2015 06:41 AM
TGGodfrey
Aug 18, 2015 06:08 PM
karpetcm
Aug 14, 2015 03:02 PM
C4m4roJoe
Jul 19, 2015 10:59 PM
