Shark vs Piranha vs NOS Fogger Nozzles
Old 03-07-2003, 02:11 AM
InjectedSS's Avatar
like the sub says... which one out of the 3 is best?
InjectedSS is offline
Old 03-07-2003, 03:58 AM
texlurch's Avatar
I have used the NOS and the Shark, with the NX jetting the Shark seems to mix better. I can tell the difference in the way the motor sounds when you hit it. (no, really!! )
texlurch is offline
Old 03-07-2003, 12:11 PM
CustomN2O's Avatar
The NX nozzle is by far superior to the NOS nozzle. Much better atomization, and tuneups. As far as between the shark and the pirhana, it really depends on the manifold you are using. If its a single nozzle deal, mounted before the throttle body, I would use the Shark. If its a direct port kit, on a stock manifold with clearance problems, I would use the pirhana. The difference is just the size. The Shark uses 1/8 pipe, and the Pirhana uses 1/16. The Shark will go above 500hp, and the Pirhana is only good till 500. Hope this helps.
CustomN2O is offline
RUENUF
03-13-2016 03:37 PM
Quickss96
01-29-2016 05:56 PM
FryedClutch
09-01-2015 08:24 AM
cardemo16
08-24-2015 01:04 AM
colts0455
07-20-2015 09:52 AM
Quick Reply: Shark vs Piranha vs NOS Fogger Nozzles
