the 100nx shot
Old 03-04-2003, 11:37 PM
hitman8728's Avatar
Exclamation the 100nx shot
ok guys well i have kinda aksed this ? befor but i have benn runnign the 100shot for few days now and then i hit it it really dose not fell like much i hear people talking about how it give u a good kick has any one here used the nx 100 shot and could fill me when what it should feel like thx alot every one...
hitman8728 is offline
Old 03-05-2003, 12:17 AM
LPEdave's Avatar
I suspect the system's not working. 100hp is a bunch, you shouldn't have to wonder if it's really working or not. Have you checked the various electronics? Scanned it while at WOT?
Dave
LPEdave is offline
Old 03-05-2003, 01:55 AM
stik6shift98's Avatar
its not gonna rip the seat back with you but you should feel that your car is faster......whts your bottle pressure at?
stik6shift98 is offline
Old 03-05-2003, 10:43 AM
speedmiser's Avatar
I know you mentioned before that you didnt know the bottle pressure. Ok... then whats the approx bottle temp when you've tried to spray. Are you running a bottle warmer? Low bottle temperature will = low pressure, even with a full bottle. Your system would be extremly rich with a cold bottle and cause a huge power loss.
speedmiser is offline
Old 03-05-2003, 12:12 PM
AutoRoc's Avatar
fhjmh
You need 1000PSI in the bottle
Starting with a FULL bottle is good
MAKE SURE you are using the reccomended jets for a 100 shot
Make sure everything is wired properly
Test the Nitrous solenoid with the bottle closed in your garage
Test the fuel solenoid while driving. Arm and engage the system while accelerating slightly. if that car nearly dies, shut the system off..it works
Open the bottle with it's 1000 PSI and activate the system at full throttle.
I don't know if you're using a throttle switch or rocker switch or a button. Goodluck. and throttle switchs are COOL. I suggest you get one and wire it up.
You WILL feel a 100 shot
AutoRoc is offline
Old 03-06-2003, 07:59 AM
95greendragon's Avatar
VERY much sounds like bottle pressure. If your bottle pressure is 600-700psi it is VERY noticeable, buy a bottle heater and a gauge and hold on!
95greendragon is offline
Old 03-06-2003, 08:28 AM
MonoxideChild's Avatar
I felt a jolt with my 75 shot, so I would guess a 100 shot would give a decent kick.
MonoxideChild is offline
Old 03-06-2003, 08:29 AM
Oh yes it certainly does when I hit it at the beggining of second it will roast the hides all the way through the gear.
Old 03-07-2003, 10:42 AM
XKnightRider's Avatar
Re: the 100nx shot
My juice comes on at 3200RPM in 1st gear and on street tires I have no traction after that till about 3rd. With ET streets on I run high 11's on the 100shot, so yeah....it should kick you good! Do as others suggest and test the system and make sure you have good bottle pressure.
XKnightRider is offline
Formula Steve
09-19-2023 08:31 AM
68camaroboltz
10-05-2015 11:56 PM
09-18-2015 03:46 PM
NewsBot
09-15-2015 11:53 AM
damnyankee36
09-09-2015 07:06 PM
Quick Reply: the 100nx shot
