LS1 Goodies for Sale-Tranny, TCs, Wheels/Tires & More
LS1 Goodies for Sale-Tranny, TCs, Wheels/Tires MTI R1 Cam & More
Getting some new parts in so I've got some stuff I'd prefer to go to good use locally.
FLP Level 4 4L60E Tranny ( http://store.flp2win.com/SearchResult.aspx?CategoryID=7) with about 14K miles used on the road and at the track. Clean, quick, hard shifting vacuum modulated and puts power to the wheels. Fluid changed about every 5K miles. It's been behind a nice soft Yank SY-3500 converter so she's got plenty of fun left for your 10 second car. A new one goes for about $2,855 ($1,999+$650 core charge and $210 round trip shipping.) Buyer keeps their stock tranny to sell ($500 - $800 for a core). Selling this tranny locally for $1,500. ---SOLD---
Yank SY-3500 Converter (258mm super high efficiency, soft launch, 3500 stall, 1.61 STR) with 30K miles. Holds the power well enough for 1.4x launches under 560rwhp. Stalls around 3,800 NA with 420rwhp so she is probably still spot on for bolt on cars. This converter works well on the street for the drag radial crowd and has cut anywhere from 1.4xs on slicks to 1.7s on DRs over it's history. Retails for $895 and could be shipped to Yank for a checkup and refresh for about $200 but I don't think it's required for a daily driver weekend warrior. I'll sell it for $300 locally. ---SOLD---
TCS Phoenix Pro 4200 2.7STR 100 miles. This one is a high stakes bet so read this carefully. My car drove through conveter and was stalling closer to 5,200 rather than 4,200 on motor. Many people were sucessfull running this converter on stock cubes but I chose not to use it and the company was closed by the owner before I could get it checked and restalled. Mike Senia at Yank was quoted on L1Ttech by PSJ saying that he would check them and restall if necessary for about $225-250. Give Mike a call to confirm he'll look at it and restall it for you. Buyer pays to ship it and restall it at Yank. If you get it back and it performs properly in your NA car, the buyer pays me by donating $50 worth of Goodies to Toys for Tots by Decmeber this year.
RCI Universal Trans Blanket wraps with Velcro belts. Keep you 10 second in step with the safety regs. Selling locally for $60.
SLP 01-02 Stainless Long Tube Headers w/o emissions (A.I.R and EGR capped). Includes off road modified (catless) Y-Pipe hammer tweaked to fit BMR or SLP drive shaft loops. Rear O2 simulators to allow you to run without cats. Sells for $800+$110 for the install kit (gaskets, bolts, hangers, O2 sensor extensions). I'll sell them locally for $450 and you can order the install kit.
SLP/Random Tech 3" Hi-Flow Cats with about a year worth of running for less than 10K. List for $340 and I'll sell them locally for $150.
MTI 20% underdrive pulley. Sell it locally for $150.
MTI R1 Cam - 232/236 .575/.578 114 LSA very streetable on 383CI and up motors. Does well on the juice too and performs well with Comp Cams 918 Blue Stripe springs. Selling locally for $250.
Stock 01 Converter with less than 1K miles for $100 for a good spare or core.
Stock 01 F-body Panhard bar and LCAs for free if you need restore pieces.
Stock 01 Throttle Body could be used for a core for a ported and polished one. $40. ---SOLD---
Stock 01 Fuel Tank w/o sending unit for $100.
Walbro GSS340 high pressure fuel pump with less than 6K miles for $70.
Stock 01 Fuel Injectors 30K miles but they've made history running to 560rwhp. Selling for $80.
Thunder Racing Aluminum Dyna-Batt Battery Hold-down, 1993-2002 F-body for $80. This will also hold the Hawker batteries which are cheaper than Dyna-Batt and can be found at www.gotbatteries.com. They can help take 20-30lbs out of your front end of the car.
Ram Chargers LS1 MAFT for $70. ---SOLD---
Original GTech by Tesla for $40.
4 x 01 WS6 17" Wheels. There are curb marks but these would make great track wheels or winter wheels. $400 locally.
Various assortment of tires sold in sets of two. Current mounted- 2 Good Year F1s (70% tread) ---SOLD---.
2 more F1s (50% tread)
2 BFG KDWS (80% tread) tires for your winter driving needs.
All tires are 275/40/17s. Best offer per set.
Centerline Convo Pros 15"x8.5" with 5'' Back Spacing and 5 x 4.75'' bolt pattern mounted and balanced with 26"x10"x15" Mickey Thompson ET Drag Slicks. The tires have had about 20 runs with about 60% tread left. The wheels will fit fine with the Stock LS-1 brakes without any modification and there are no clearance or rubbing problems with the slicks. The wheels are in good shape with no curb rash. They come with the center caps and I've got two sets of washers and 2 or 3 sets of big lugs for the 5/8" studs. The combo lists for about $700 but you can have them on your F-body for the June 5th race for $325. ---SOLD---
Rick
Rick
Originally posted by PhantomTA
Rick,
I want your throttle body
Rick,
I do need to hit you up for the location of a copy of the MAFT instructions. It's an older 4.2 box but I'm sure the current stuff will probably be pretty similar.
Rick
