Z wont start,guages are stuck,fuel/waterpump wont come on when key turned! HELP!
Well Its saturday morn. I go out to the trusty Z28 and put the key in and try to turn the car on. Guess what nothing. The guages are stuck(They all arent on the bottom, thermostat a little higher than 160 and oil a little higher than the lowest line) and I cant even hear my electric waterpump or new 255lph fuel pump turn on when i press the key all the way back.By the way it isnt the battery because my stereo and windows even the power doorlocks work. I even just came back from gay *** local parts store and I brought a coil just for the hell of it tried it and no go (which is what i figured) My only guess now is the key tumbler or the ignition control module. Im so pissed off! My Mustang is all apart and the motor is at the machine shop so i cant even drive that. Please help! Im trying to get ahold of my mechanic but cant and he lives 1hr away so im pretty much f*cked. Thanks alot CZ28.com
yeps its your ignition swicth...they are like 20-45 $ but a bitch to get to kinda....if you dont knwo what you are doing then yea its hard, but if you do it should be easy....look at shoebox tech page..i got it off of there when i replaced mine and those directions are like 101% correct and good!!!
good luck
good luck
Thanks for the reply. Im gonna have to go to a Chevy dealer to get this. The local parts shops will take 3-5 to get it. I hope it really is the ignition switch cause i need my Z!
10-31-2016 11:09 AM
Oncomingstorm22
01-22-2015 07:15 PM
formula79
26
08-05-2002 12:21 PM
