Whats the best choice for head upgrade?
Re: Whats the best choice for head upgrade?
Would help if you define your goals.
IMO the stock castings are probably enough. Guys are doing 450 to the rear wheels and better with good porting.
-Mindgame
-Mindgame
Sorry. We were discussing supercharging an LT1 with all internals stock on another board. Some of the guys thought the results of the bolt on s/c only were fairly modest, and not much better than a good cam and heads upgrade. The suggestion was LT4 heads(Corvette board of course). The goal would be to make an LT1 C4 Vette quicker in a straight line than a Z06 so I would be thinking close to 450 at the crank. So 150hp over stock.
All that said, and looking at your goal, this is overkill in a big way.
The stock heads with excellent porting and a very drivable cam in a 350 will put you over 400hp at the rear wheels. That should be enough power to put you in the 11's with a streetable suspension setup, good 60' times and full weight car.
Many of the C4's out there would see nothing but Z28 all the way down the track.
-Mindgame
Are Lt4s worth a look? Are they as good as the Edelbrock Performers?
Thanks guys! I just came out of the Adanced Induction Site and they pretty much reached my goals by porting stock heads. I was figuring the head upgrade and then the porting but based on this, who needs the LT4?
10-31-2016 11:09 AM
95chwagon
01-13-2015 09:19 PM
