timing set
Old 01-15-2015, 02:13 PM
chuyz28's Avatar
timing set
Hello guys I'm doing a cam swap in my z28 just bought a cloyes
C3039 anyone used this set before it's for my 96 z28 says it's for Lt1
But can't find no info thanks in advance
chuyz28 is offline
Old 01-15-2015, 04:14 PM
Re: timing set
Looks like the correct set, with the gear on the back of the cam sprocket for the water pump drive. And the hole in the center is the larger hole, required for the pilot shaft on the vented Opti (95-97).
Injuneer is offline
HectorM52
07-30-2017 11:46 AM
10-31-2016 11:09 AM
Jlo
02-03-2015 09:41 PM
01-23-2015 01:13 PM
Queens94z28
12-20-2014 09:11 PM
Quick Reply: timing set
