Opti Gaskets, Waterpump Gaskets
Looking at the "http://www.streetillusionsracing.com/Install/opti/opti.htm" page for how to install an opti. Just have a quick question about what gaskets I will need? This will be my first Opti install
The page lists two Waterpump Gaskets. But, after reading a few posts on the board I heard people mention they need two Optispark O rings (or gaskets?).
Are these the same thing? or will i need 2 Waterpump gaskets and 2 Optispark O-rings/Gaskets?
Thanks.
Thanks.
Re: Opti Gaskets, Waterpump Gaskets
2 water pump gaskets GM p/n 10128343
2 water pump drive shaft Orings 12553792
Opti Orings I dont have the p/n [I have a 94 unvented opti you have a 95-7 vented opti]but they are not the above parts..they[or it?] go on the shsft whee it inserts into the cam..
Above parts should be about a buck each or less..
Check the crank, waterpump, and opti seals for oil leaks while you have it off..
Originally Posted by Mtrhds94Z
Try 10474278 I found it in some lists I have.. pretty sure it's correct.. not sure if you need one or two tho..
Sergio
01-27-2016 04:27 PM
Dan_the_ManZ28
02-21-2015 02:01 PM
lbrowne
11-13-2011 04:25 PM
