Oil Pressure Gauge
Re: Oil Pressure Gauge
First you'll need a mechanical gauge that has a length of hose attached to it with a 1/4 inch pipe thread. There are two plugs over the oilfilter boss on the drivers side, engine off, remove the lower one and thread the end of the oil pressure gauge into it, tighten and stat the car, should read good oil pressure here.
