Off idle stumble/hesitation, Intake backfire @ WOT
Old 04-19-2010, 10:04 PM
briand069's Avatar
Hi all,
I'm stumped at the moment. I am trying to troubleshoot this problem but have hit a road block on where to turn next. Car idles smooth, drives fine but when you hit the throttle at idle it hesitates then revs fine. If you go WOT off idle it backfires through the intake once. While cruising, going WOT it will backfire once through the intake and appear to run fine. I've attached a log of a run and it looks like the left side leans out. Rec #'s 4492,5328 & 5754 are just before it backfires when going WOT on the freeway. At the end of the file, 3-4 times at idle I hit the throttle and it hesitates. What I have tried so far is plugs, checked wires, opti is new but not replaced for this problem, fuel pressure checks out, compression looks good (within 10 psi) and I have checked for vacuum leaks and cannot find any. This is the LT1 in my 69. All emissions deleted, mostly stock tune from a Corvette. If anyone has time and can look at the log and give me some more suggestions I would appreciate it.
Brian
http://www.gigasize.com/get.php?d=5wk5wmbxfkc
briand069 is offline
Old 04-20-2010, 05:27 AM
"Download Error - This File Has Been Deleted."
Injuneer is offline
Old 04-20-2010, 05:48 AM
briand069's Avatar
Odd. I just downloaded it again from another computer. Can you please try again?
If that one still doesn't work, try this one.
http://rapidshare.com/files/37825449..._run2.csv.html
Maybe this one will work. :/
Old 04-20-2010, 07:27 AM
Mystery Bird's Avatar
I have recently developed the same problem. Adjusted throttle body for split BLM's and it got worse.
Mystery Bird is offline
Old 04-20-2010, 02:12 PM
In your post "this one" is a box with a red X in it.
Injuneer is offline
Old 04-20-2010, 09:03 PM
briand069's Avatar
Well, I'm not sure what to try next for uploads. I can click on both links and download the file though. If they don't work what else can I try to host the file?
Old 04-21-2010, 11:02 AM
briand069's Avatar
If someone wouldn't mind, can you please see if this link works.
http://www.mediafire.com/?zcwyt5zkzwt
Thank
Brian
Old 04-21-2010, 05:51 PM
It downloaded. Almost gave up when I clicked "download" and it popped up a hotjobs sign-in screen.
Huge file, will be a while before I can get to it.
Injuneer is offline
Old 04-21-2010, 05:55 PM
briand069's Avatar
Right on. Sorry about all the trouble posting the file. Most of the issues occur around the record numbers I listed but it you see something else let me know.
Brian
Old 04-24-2010, 05:23 PM
briand069's Avatar
Ttt
Old 04-24-2010, 06:45 PM
Mine went away when I pulled the coil wire, put some dielectrical grease on both ends and turned the throttle body screw out about 1/2 turn.
Old 04-28-2010, 02:34 PM
briand069's Avatar
Well, I seem to have finally figured, well fixed at least, my troubles. After rechecking everything mechanical electrical I wet back to the tune. I had tried several different F-body bins and all resulted in the same hesitation/backfire trouble. The PCM I have came from a 94 Vette with the $EEB file but I could never get it to work because I didn't have the CCM. But, after downloading the most recent Tunercat I saw they added a option "Data stream fuel enable". So I reloaded my original tune with that option unchecked and low and behold it worked. I've read that loading the different bins shouldn't matter but for what ever reason mine seems to like the $EEB tune. Go figure.
Brian
Old 04-28-2010, 02:49 PM
mel0n666's Avatar
my 94 z28 does the same thing...... i dont think it has ever not done it... i have just assumed it was because of the cam and because of the 2500 stall tq converter.
mel0n666 is offline
kallcium
V6 Tech
10-07-2015 03:39 PM
maybe2fast
03-16-2015 11:59 AM
jayblev95
01-20-2015 01:30 PM
bfmv13trivium
01-14-2015 09:57 AM
F(ast)-body
02-26-2003 09:05 AM
Quick Reply: Off idle stumble/hesitation, Intake backfire @ WOT
