Weak starting
Old 07-12-2014, 03:45 AM
Chet1185's Avatar
Weak starting
At first start up, she turns over easily. after I drive then shut it off and go to start it back up, she turns over very lazy and even stops in the middle of turning over. Even my fuel pressure gauge changes color like I unhooked the battery.
I installed a new LT4 starter, newer cables and its a good battery. any ideas?
Chet1185 is offline
Old 07-14-2014, 10:14 PM
Chet1185's Avatar
Re: Weak starting
Also a new motor so the ground should be nice and clean
Chet1185 is offline
Old 07-14-2014, 11:18 PM
ACE1252's Avatar
Re: Weak starting
How do you get it back to an "easy start" condition? Is it cooling off then just starts easy again?
ACE1252 is offline
Old 07-15-2014, 05:01 AM
Chet1185's Avatar
Yes.
It has done this ever since i bought it. Now i have the Corvette starter and long tubes.
Chet1185 is offline
Old 07-15-2014, 05:03 AM
Chet1185's Avatar
Re: Weak starting
And a different column and ignition switch.
Chet1185 is offline
Old 07-15-2014, 01:38 PM
pizzi-man's Avatar
Re: Weak starting
Change your battery.
pizzi-man is offline
Old 07-15-2014, 09:04 PM
Chet1185's Avatar
Re: Weak starting
Battery is fine. Also did it with a brand new one
Chet1185 is offline
Old 07-26-2014, 05:25 PM
HardcoreRM125's Avatar
Re: Weak starting
Does it have an aftermarket tune?
If the timing was advanced enough on cranking RPM's I could see it being a problem once it is hot and running on Closed Loop.
HardcoreRM125 is offline
Old 07-27-2014, 01:02 AM
raroz28's Avatar
Re: Weak starting
my car has done the same thing for years. Starts fine cold but if it's warm it has a hard time turning over and will stop in the middle then muster up the power to turn over.
replaced battery, starter, wrapped new starter in starter heat wrap, grounds are good, etc.
The only thing left for me to try to replace is the ignition switch.
raroz28 is offline
Old 07-27-2014, 10:01 AM
Re: Weak starting
Are you sure it's "nice and clean"? Was the block painted?
Injuneer is offline
Old 07-27-2014, 10:02 AM
Chet1185's Avatar
Re: Weak starting
No paint.
Chet1185 is offline
Old 07-27-2014, 10:19 AM
Re: Weak starting
Did you check the cables for corrosion?
Injuneer is offline
Old 07-27-2014, 10:20 AM
Chet1185's Avatar
Re: Weak starting
I bought a replacement used set. They looked good when i installed the new motor. I cant see any corrosion but that doesn't mean there isn't any. I have cut wires before and inside they are corroded.
Chet1185 is offline
Old 07-27-2014, 10:50 AM
Chet1185's Avatar
Are these the part numbers
12157374
12157373
Chet1185 is offline
Old 07-27-2014, 03:12 PM
raroz28's Avatar
Re: Weak starting
Can anybody confirm that the symptoms the OP is having is caused by the ignition switch? My car just started doing it out of nowhere. All of my grounds were cleaned when I had my motor out for a rebuild so I can confirm that they're all good.
I've replaced everything else and the only thing I ever read that could cause it as well was the ignition switch but I never wanted to take the time to replace that.
raroz28 is offline
Quick Reply: Weak starting
