connecting rod bearings
Hey Members,
Is there any easy way to replace connecting rod bearings when engine is in vehicle. I have to replace my oil pan. thought it would be a good idea to look in this area while everything is pretty accessible. Don't know exact mileage on my Lt1. Thanks
Re: connecting rod bearings
You can also change the main bearings by rolling the block side half into place. I put a tool into the oil hole and turned the crank.
Good luck!
