Cold start issue.
Old 11-03-2014, 07:02 PM
Red97LT1's Avatar
Cold start issue.
Started the car this morning and it was cold (25 degrees) and almost immediately it wanted to die,until I gave it a little gas. Once I let up on the gas the idle dropped and it almost died again.I gave it gas for a few more seconds and then it was fine.
Now I am thinking it may be the IAC valve since I didn't notice the rpm going higher when cold and then dropping when the car warmed up.The rpm also seemed to drop low when I was shifting from Reverse to Drive. I'm going to check the IAC tomorrow using the diagram from shbox,but was wondering what else may cause the issue?
Red97LT1 is offline
Old 11-04-2014, 09:41 AM
Re: Cold start issue.
I'd start by checking the coolant temp sensor. The PCM sets the cold start idle RPM and richens the mixture for cold start based on the coolant temperature.
The IAC may also be suspect. Shoebox has a test procedure. This is a case where a scanner would help by showing you the coolant temp the PCM is seeing, and how it adjusts the IAC counts to control the RPM.
Injuneer is offline
Old 11-04-2014, 10:48 AM
Red97LT1's Avatar
Didn't think of the temp sensor, thanks. I'll use Garys software when I get home and get a log.
Red97LT1 is offline
Old 11-04-2014, 05:03 PM
Red97LT1's Avatar
So if it is the coolant temp sensor,I need the one up front near the water pump right? which is
http://www.amazon.com/ACDelco-213-4396-Professional-Coolant-Temperature/dp/B001DRG57Q http://www.amazon.com/ACDelco-213-4396-Professional-Coolant-Temperature/dp/B001DRG57Q
Red97LT1 is offline
Old 11-04-2014, 06:13 PM
The PCM reads the CTS in the water pump housing. It is a 2-wire sensor. I don't have the part numbers memorized. Shoebox has them on his website.
Injuneer is offline
94Form
02-10-2015 11:23 PM
Gtpguy
01-26-2015 04:50 PM
Alex Barnes
01-24-2015 10:21 PM
01-23-2015 01:13 PM
Britbilly
01-07-2015 08:49 PM
Quick Reply: Cold start issue.
