Help me out guys broken heder stud that connects to y pipe on stokc manifolds????
Old 05-20-2004, 08:49 PM
TexasTechTA's Avatar
alright heres the deal i was taking off my stock y pipe today and was using an im pact and the stud broke of the manifold that has the nut on the end on both manifolds one on each side. anyway there is an exhaust leak now and it sucks. can a muffler shop drill the end of the snapped stud off the 2 manifolds and put bolts in there???? I am desperate
TexasTechTA is offline
Old 05-20-2004, 09:19 PM
25thBird's Avatar
You won't know until you ask an exhaust shop, but my guess would be that they can take are of that for you.
25thBird is offline
Old 05-20-2004, 10:22 PM
Larry95Z28's Avatar
I broke off some of the studs on mine when I removed the y pipe. I had to take the manifolds off anyway so I just heated up the manifolds and used a small pliers or pipe wrench and they turned out really easy. I know this would be a real pita if you didn't need to pull the manifolds out. I guess if you were careful you might be able to do it in the car.
Larry95Z28 is offline
Old 05-20-2004, 10:23 PM
Spinner's Avatar
Time to buy headers
Spinner is offline
Old 05-20-2004, 11:13 PM
money si real tight now. so no headers. But you guys think they can get them out? there is plenty of the head showing to get pliers on
Old 05-20-2004, 11:20 PM
Spinner's Avatar
If you can see head, why not do it yourself with vicegrips.
Spinner is offline
Old 05-20-2004, 11:22 PM
I did not know what to do when they snapped but will hopefully try tomm, althouhg I think i am still gonna take it to a muffler shop it sucks getting under that low *** car with a little jack and trying to take the y pipe off
Old 05-21-2004, 12:52 AM
93fblt1's Avatar
Talking
Hi there, I did the same last saturday. Here is my temporary solution. I used a small clamp(similar to c-clamp) from work to hold the broken bolt end down and slowly tighten the other two nuts. This clamp has a bolt to tighten. It seems to stop the leaking until I change to exhaust header. Hope this will help. The muffle shop can drill the broken bolt out but it will cost!
93fblt1 is offline
94Z28LS1toLT1
01-15-2015 07:18 PM
spearous
01-12-2015 11:03 AM
thenewkid
11-18-2014 12:57 PM
07-04-2005 05:00 PM
Red97LT1
08-07-2002 05:45 PM
Quick Reply: Help me out guys broken heder stud that connects to y pipe on stokc manifolds????
