sts or le2 or le3?
sts or le2 or le3?
i have a 95 formula with 6 speed spec stage 3 clutch 160 stat pacesetter long tubes no cats and borla cat back thinking either sts or le2 or le3 no goals in mine just to haul *** thanks for any input
Re: sts or le2 or le3?
it would be easier to start with the head and cam. If you have the money then go with LE3 had and cam. Then if you want more you would have the heads to support the forced induction needs of bigger power. Also you would need to look into internal parts to properly support boost
Henson071
08-04-2015 09:32 AM
