Broke a rocker stud
Old 11-05-2006, 06:49 PM
JimboManJones's Avatar
Broke a rocker stud
sucks, but at least I already have my 7/16 studs and non self aligning roller rockers, chromeoly push rods, and guideplates ready to go, guess this is the incentive to git r done
Any guess as to what could've caused it, I shift at 5700, can you make the poly locks too tight? I am running lt4 springs and the rockers are 1.6 SA proforms(changing over to comp pro mags(NSA) with arp 7/16 studs)
It broke at idle pulling in to my driveway and the rockers have been on for over 1500 miles, just curious as to how it could break on a stock cam, and it was the number 3 intake rocker if that helps.
They were stock 3/8s studs btw
JimboManJones is offline
Old 11-05-2006, 10:56 PM
MeanGreen97Z's Avatar
Did it damage the valve? Look on the top of the valve for it being rounded on the side. The rockers may have been too tight or the stud might have been old.
MeanGreen97Z is offline
Old 11-06-2006, 08:19 AM
The valve is okay, I did a 1/2 turn past zero lash, how tight are you supposed to make the poly lock?
Old 11-06-2006, 08:40 AM
Z07
Z07's Avatar
Were they ARP? Did you have at least half an inch of thread passing through the rocker arm into the poly lock?
Z07 is offline
Old 11-06-2006, 09:11 AM
They were stock, GM, screwed in 1996, 3/8 rocker studs, I don't think I had a half inch of thread screwed into the poly lock, I'll have to check when I get home.
The new ones I have are 7/16 arp
13qtr
10-28-2016 08:11 PM
truecontr3
10-11-2015 09:30 AM
DelSoto
09-19-2015 05:31 AM
mmf_1013
09-12-2015 08:56 PM
Daluchman1974
09-11-2015 06:12 AM
Quick Reply: Broke a rocker stud
