Rear Axle Shaft Ideas
Old 04-09-2012, 08:58 PM
akwa's Avatar
Arrow Rear Axle Shaft Ideas
What axle should i upgrade to and what do i have? I have heard that moser is the best but i have traction control, abs, asr etc and i dont know what i need or what to look out for while installing? I can get oem from a scrap yrd or ebay cheap but i dont wanna do this again soon as the car gets drove pretty hard. Ideas?
Response to my last post: So my rear axle has been deemed the coulprit of grinding noise under my car. while inside the car i had thought it was comming from the front but after walking next to it i noticed it came from the back. jacked it up and noticed that on both sides the rear wheels while in drive were wobbling a little. they felt solid when i pulled, pushed etc on them. If its something else or minor wobble is normal please stop me before i waste money lol
akwa is offline
Old 04-09-2012, 08:59 PM
akwa's Avatar
Re: Rear Axle Shaft Ideas
PS the car is a 98 z-28 ls1
akwa is offline
Old 04-09-2012, 09:13 PM
96capricemgr's Avatar
The carrier and pinion are so weak I don't think hardly anyone worries about the shafts the other parts break long before. If you have real reason to believe the axles are damaged I would just get used parts from someone who went to a stronger housing.
96capricemgr is offline
Old 04-10-2012, 04:45 AM
mrmint69's Avatar
https://www.camaroz28.com/forums/dri...t-axle-647857/
Did a search and little info with not much response. I would think just getting a used one and checking it at the wrecking yard would be the best thing. I assume backing into or hitting the rear tire bent the axle. Could have been there when you bought the car.
Does anyone know if doing donuts in a parking lot of being hard on the car in general could have bent the axle, or would it have been from an impact? I had a bent axle when I bought my car and I assume it was from backing into a curb or striking something.
mrmint69 is offline
QuickSilver02
04-07-2015 11:12 AM
Chet1185
02-04-2015 09:51 PM
4586
01-03-2015 07:22 PM
nodnarb481
Middle Atlantic
01-01-2015 11:43 PM
rockync7
01-01-2015 05:10 AM
Quick Reply: Rear Axle Shaft Ideas
