Pics of SLP SFC´s?
Old 03-29-2003, 08:20 AM
OliGeorgs's Avatar
Pics of SLP SFC´s?
Please post pics of SLP subframe connectors installed. I´m inetersted in where they are attached.
OliGeorgs is offline
Old 03-29-2003, 02:32 PM
M3EATER's Avatar
Are you talking bolt-on or weld on?
M3EATER is offline
Old 03-29-2003, 05:04 PM
OliGeorgs's Avatar
It doesn´t matter, they are almost the same.
Old 03-30-2003, 04:25 PM
M3EATER's Avatar
I don't have a shot of mine that I can post right now....
But...
On the bolt-ons..... The rear attachment point id the forward mount for the LCA. The bolt goes through the bracket on the SFC. There is also another bolt that goes up through a hole in the subframe & screws through a backer plate that you slip up through a hole.
The front has two bolts thqt go up into existing holes in the subframe & a backer plate is inserted into the subrame through another hole.
The center traingulated mounts go the the 2 bolts for the tunnel cross plate.
Gordon
www.provenperformanceconcepts.com
M3EATER is offline
Fastbird93
04-09-2016 07:01 PM
HarleyZ28
10-05-2015 06:23 AM
87Aerocoupe
01-10-2015 07:27 PM
routesixtysixer
06-23-2002 02:29 PM
Quick Reply: Pics of SLP SFC´s?
