MAF for 98 SS
Old 06-10-2015, 09:20 PM
1996LT1Z28's Avatar
MAF for 98 SS
My son bought a 1998 SS that needs a new MAF.
Can someone tell me if its the same as the stock GM one or does SLP put in a bigger unit.
Either way, I need part numbers or any info that would give me a point to start from.
Thanks,
Mike
1996LT1Z28 is offline
Old 06-11-2015, 08:18 AM
87DJP2001's Avatar
Re: MAF for 98 SS
Wells SU-1102 would be a good start.
87DJP2001 is offline
Old 06-28-2015, 10:13 AM
transamtom's Avatar
Re: MAF for 98 SS
Delco AF 10056 fits 93-2002 F Bodies.
transamtom is offline
Old 07-06-2015, 07:13 PM
Super Moderator
JakeRobb's Avatar
Re: MAF for 98 SS
Tom, that's Delphi, not ACDelco. Otherwise correct.
For electronics (and especially sensors), I've found that OEM parts like that one are always best by a long shot. RockAuto carries it for under $100. They have equivalent parts from other manufacturers at lower prices, but I've tried those and it's never worth the cost savings. You can have 120,000 miles worth of reliable performance from the factory replacement part, or you can save 20% for a part that will fail in 40k or less.
JakeRobb is offline
Double aught
10-02-2015 11:29 PM
marlar98
09-19-2015 07:53 AM
tommalcolm
09-11-2015 03:39 PM
sleeperZ96BT
09-10-2015 08:01 AM
damnyankee36
09-09-2015 07:06 PM
Quick Reply: MAF for 98 SS
