Ls1 stock. Replacing spark plugs
Old 08-17-2013, 11:16 PM
mrmint69's Avatar
My stock lt1 spark plug change took three hours. Getting ready to do a ls1 stock for the first time. How long should it take? Any special tools or tricks for these? What are the best plugs for them? Thanks!
mrmint69 is offline
Old 08-19-2013, 05:19 PM
transamtom's Avatar
Re: Ls1 stock. Replacing spark plugs
I used NGK Iridium plugs
If your running nitrous use a regular copper plug.
The LS1 should be a bit quicker,#8 needs to be done from the bottom.
transamtom is offline
Old 08-20-2013, 01:54 PM
WhiteHawk's Avatar
I get #8 with a tiny snap-on 1/4" ratchet, a 1/4" to 3/8" adapter, and then a standardplug socket on the end. It is blind but I am pretty good at it after doing it a few dozen times. I always pull off the coilpacks too to make it easier to get my hands in there.
-Geoff
WhiteHawk is offline
Old 08-20-2013, 08:01 PM
Mr99SS's Avatar
I bought reg copper plugs getting them changed tomorrow with msd wires gates belts an changing coolant . im looking for high 12's tomorrow for a baseline
Mr99SS is offline
Old 08-22-2013, 08:49 AM
mrmint69's Avatar
Took two hours including a compression check. Eight is crazy, but only took forty minutes. Thank goodness it was not on tight and threaded in easy. Thanks for your help!
mrmint69 is offline
Old 08-31-2013, 02:19 PM
Mr99SS's Avatar
yeah pass side is hardest side
Mr99SS is offline
Dan_the_ManZ28
02-21-2015 02:01 PM
mritter1965
02-09-2015 07:01 PM
Iamherefornow
01-26-2015 04:57 PM
Jazsun
12-29-2014 12:14 PM
Quick Reply: Ls1 stock. Replacing spark plugs
