how does a bent pushrod cause a loud tapping noise?
Old 06-29-2003, 02:00 PM
MattysTA's Avatar
Ive heard people saying that a bent pushrod will cause a loud tapping after doing searches but how does it if it is tightened between the rocker and lifter?
MattysTA is offline
Old 06-29-2003, 05:14 PM
NJDevils88's Avatar
I think it is slapping around inside the sleeve...I'll tell you what... my engine started a small ticking noise... and I did have an all famous mis-shift.....and shortly after I started to notice a small ticking noise if you got down near the front passenger wheel-well. So I tore out the valve covers and removed the rockers. From here I pulled the rods, but the were all fine. Pulling the damn valve-covers took an crazy amount of time--they have everything but the spare tire mounted to these SOB's. At this point my hands were so scrathed to hell from the fastners under the dashboard, in the engine compartment, that I was disgusted. I just put the damn thing together. God knows what it is. Sounds more like a steady ticking. Anyone have any ideas?
NJDevils88 is offline
Old 06-29-2003, 06:39 PM
crazyswede1027's Avatar
steady ticking could be piston slap also. GM service center would know for sure.
crazyswede1027 is offline
Old 06-29-2003, 06:45 PM
dis3as3d's Avatar
If you think you have piston slap check out this website, it should help you out LINK
dis3as3d is offline
13qtr
10-28-2016 08:11 PM
CARiD
09-30-2015 05:44 AM
surreybrad
09-29-2015 09:00 PM
autoxr166
09-25-2015 04:21 PM
Matt Dreessen
09-09-2015 09:58 PM
Quick Reply: how does a bent pushrod cause a loud tapping noise?
