Direct Flo Lid
Old 04-02-2003, 11:47 AM
BlackZin01's Avatar
Direct Flo Lid
Does anyone have a picture of the direct flo lid installed on a 01 or 02? I just put mine on and I can't find a good place to tie down the tube that used to go into the driver side baffle.
Thanks in advance.
BlackZin01 is offline
Old 04-02-2003, 12:28 PM
psychocabbage's Avatar
I took my tube and put it on the right hand side with the filter on it.. i felt all around the tube to make sure it isnt kinked.. its how i run it when i put on a lid but at this moment i have it all stock.. i think i have a pic.. lemme see..
psychocabbage is offline
Old 04-02-2003, 10:02 PM
BlackZin01's Avatar
Thanks! In the meantime, I just mounted it with some tie wraps. Doesn't look to bad. Where does that tube go anyway? I followed it for a bit and then lost it. Why don't they have them for the years prior to 2001? Thanks again!
Old 04-02-2003, 11:13 PM
Z-Attitude's Avatar
The hose is the suction to the air pump that is under/behind the left headlight. I just rolled the hose till I could tie wrap it to a harness near the fuse block and brake module. Kinda hid the filter under it. Just no kinks, it needs to suck air. Later>>>>>>>
Z-Attitude is offline
Henson071
09-18-2015 04:01 PM
cmsmith
09-14-2015 09:25 PM
Bails098
08-17-2015 05:15 PM
surreybrad
08-10-2015 09:34 AM
RX Speed Works
07-24-2015 02:25 PM
Quick Reply: Direct Flo Lid
