What relay controls the headlights going up and down
Old 04-01-2010, 01:18 PM
gritter94's Avatar
So i've been having issues with my headlights not auto going up and down.. I checked the gears both ok,all wires hooked up. I don;'t have an owners manual, is there a relay that controls the headlights gonig up and down? If so which relay is it?
Car is 1994 trans am lt1
gritter94 is offline
Old 04-01-2010, 03:30 PM
You can download an owner's manual here.
I am not an expert on Firebird headlights, but there is a headlight control module by the air box.
shoebox is offline
Old 04-02-2010, 11:58 AM
gritter94's Avatar
I'm 99% sure this problem started after switching from stock air intake to lingenfelter. what's the control module look like? Maybe i disconnected it :/, damn headlights got me stumped.
Old 04-02-2010, 12:13 PM
gritter94's Avatar
Just did some searching.. The control module is bolted to the stock air box right? If that's the case that's for sure my problem as i didnt remove the control module from the stock box!
Old 04-02-2010, 01:45 PM
1995blackttopta's Avatar
this is what the contol module looks like. I added an oem blockoff plate and relocated mine down there when i added ram air.
1995blackttopta is offline
Old 04-05-2010, 10:24 AM
gritter94's Avatar
that was it! headlights work flawless now!
Old 04-05-2010, 02:06 PM
NJ-LE's Avatar
Not to hijack the thread (sounds as though gritter94's problem is solved)
1995blackttopta:
You mention "I added an oem blockoff plate" ... would you happen to have the part number for that piece?
NJ-LE is offline
CARiD
06-18-2015 08:56 AM
ChrisFrez
02-15-2015 08:12 AM
94Z28LS1toLT1
02-10-2015 10:19 AM
Injuneer
Advanced Tech
01-15-2015 02:49 PM
Quick Reply: What relay controls the headlights going up and down
