What relay controls the headlights going up and down
So i've been having issues with my headlights not auto going up and down.. I checked the gears both ok,all wires hooked up. I don;'t have an owners manual, is there a relay that controls the headlights gonig up and down? If so which relay is it?
Car is 1994 trans am lt1 |
You can download an owner's manual here.
I am not an expert on Firebird headlights, but there is a headlight control module by the air box. |
Originally Posted by shoebox
(Post 6317970)
Just did some searching.. The control module is bolted to the stock air box right? If that's the case that's for sure my problem as i didnt remove the control module from the stock box!
this is what the contol module looks like. I added an oem blockoff plate and relocated mine down there when i added ram air.
http://carphotos.cardomain.com/ride_...0230_large.jpg |
that was it! headlights work flawless now!
Not to hijack the thread (sounds as though gritter94's problem is solved)
1995blackttopta: You mention "I added an oem blockoff plate" ... would you happen to have the part number for that piece? Thanks |
