Vacuum Line Diagram and routing
Old 07-10-2014, 03:50 PM
BlackZ28_93's Avatar
Wassup Camaro fans. Does anybody know where I can the correct vacuum lines diagram and routing for a 93 Z28 Camaro LT1? In the midst of restoring my car and have broken vacuum lines but don't know where they go. NEED HELP! 😩🙏
BlackZ28_93 is offline
Old 07-10-2014, 07:15 PM
Re: Vacuum Line Diagram and routing
Is the vacuum diagram still on the radiator cover? That will be specific to your 93, which has a few differences compared to 94 and up.
You can try shbox.com, but his photos are of a 95. If all else fails, I can give you a link to a free download of the 93 factory manual.
Injuneer is online now
Old 07-11-2014, 07:18 AM
Response: Can you please send me that link!? I think that would do me more justice because I didn't see the diagram on radiator cover
Old 07-11-2014, 11:10 PM
LINK: 4TH GEN SERVICE MANUALS; 82-02 PARTS DIAG; 99-02 WIRING DIAG - Firebird Nation
The label on the radiator cover would look like this (but this one is for a 95):
Courtesy of Shoebox
On your 93, the fuel pressure regulator is in a slightly different position, the PVC hose is different (same as 94) and you will not have the line that shows "to dist".... that's for the vented Optispark, that was used 95 and up.
Old 07-12-2014, 05:23 PM
Courtesy of Shoebox
Decent! I found the diagram on my radiator cover. I didn't even look at it in the beginning. So in other words do I have to worry about the "to dist" line?
Old 07-12-2014, 05:33 PM
No. Your Opti is "unvented" and doesn't have a vacuum connection. But the vacuum connection for your PCV valve is not under the throttle body. There is a U shaped hose thar goes from the PCV to one of the vacuum ports a few inches behind the PCV. I'll post a pic later when I'm not on my phone.
Old 07-15-2014, 06:41 AM
Decent. I'm waiting for that pic. I'm going to put some more work into it today.
Old 07-15-2014, 12:01 PM
Looking at the connections:
-top, right is the brake booster vacuum line.
-below the brake booster, slightly to the right of it, is the vacuum connection for the "U" shaped line from the PCV valve - you can't see the actual connection in the picture.
-top, left is the connection for the EGR vacuum hose. Mine as a second line tee'd into it, because I converted to a vented Opti. On yours, the 90-deg elbow from the EGR hose will go directly to the nipple on the intake manifold.
-below the EGR connection is a grommet for the PCV valve. The valve sticks into a passage that connects to the lifter valley at the bottom of the intake manifold.
This shows the line from the upper connection on the passenger side of the throttle body to the passenger side valve cover:
Shoebox shows the connections on the passenger side of the intake - vacuum for: HVAC, fuel pressure regulator, EVAP purge
http://shbox.com/1/evap_sol.jpg
11-18-2023 07:21 PM
Nellsw88
05-26-2015 05:55 AM
Patrick Kovack
03-08-2015 09:26 AM
grgguy
17
02-23-2015 07:57 PM
Quick Reply: Vacuum Line Diagram and routing
