serpentine belt tension
does anyone know what the belt tension should be on a 94 camaro 3.4? and also how to replace the belt tensioner? could a bad tensioner cause the car to run hot at idle but once moving the car runs fine. any help
would be appreciated.
Re: serpentine belt tension
that cant be the cause of the problem. sounds like your fans arent coming on. check that first. if the water pump wasnt spinning as fast as it should, youd be running hot regardless. perhaps even more while driving.
i assume its the same as most cars. find it, and there should be 2 bolts holding the base down on the block or head. take those out, and it should come right off. make sure the belt is off before you do this
