Fan ?
Old 05-19-2005, 03:02 PM
tripdoc6's Avatar
Fan ?
I have a 98 SS and everytime i start the car i hear this winding noise. It starts to get a higher pitch then drops to a lower pitch at idle and only lasts for about 2min. Im thinking my fan motor is goin. Any other opinions?
tripdoc6 is offline
Old 05-19-2005, 03:18 PM
2001NBMZ28's Avatar
Re: Fan ?
Since it only lasts about 2 min you sure it's not the air pump coming on? You can pull the fuse (it'll throw a code, but go off after a few cycles) and see if the noise stops. Just something to try.
2001NBMZ28 is offline
Old 05-19-2005, 03:38 PM
tripdoc6's Avatar
Re: Fan ?
Ok no im not sure if its the pump or not but i will give it a try thanks.
tripdoc6 is offline
Old 05-19-2005, 03:53 PM
tripdoc6's Avatar
Re: Fan ?
Ok i just pulled the fuse to it and it didnt make any noise so that was the problem. What do i do to fix or is that just the normal sound. Which would be kinda weird if it was normal.
tripdoc6 is offline
Old 05-19-2005, 04:00 PM
teke184's Avatar
Re: Fan ?
options:
replace the pump...
keep the fuse out and deal with the SES...
remove the pump and have it tuned out of the ECM so you don't deal with the light
teke184 is offline
Old 05-19-2005, 04:13 PM
2001NBMZ28's Avatar
Re: Fan ?
I'd give it a few more cold starts just to be sure. The pump shouldn't be loud/whistling sould hardly be noticeable. Here's a link if you decide to yank it: http://www.ls1camaro.net/sections.ph...ticle&artid=70
Old 05-19-2005, 04:24 PM
2001NBMZ28's Avatar
Re: Fan ?
BTW, it won't hurt you to run around with the fuse out, even when it illuminates the SES light.
Old 05-20-2005, 10:53 AM
tripdoc6's Avatar
Re: Fan ?
Thanks for the help guys.
tripdoc6 is offline
Formula Steve
09-19-2023 08:31 AM
93 RedBird
11-15-2015 08:24 AM
Matt Dreessen
09-09-2015 09:58 PM
Pwilson59
09-03-2015 08:47 PM
4586
08-24-2015 11:04 PM
Quick Reply: Fan ?
