Swap on Non Comp Controled Carb & Dist What do I do with ECM?
Old 03-08-2013, 07:56 AM
BLACK Z !'s Avatar
Hi, I am taking off the Elec Controlled Q Jet and Dist, Putting on a 650 DP and a MSD Dist what do I do with the ECM? Is it controlling anything at this point? Can it hurt Perf and Mileage?
BLACK Z ! is offline
Old 03-10-2013, 08:53 PM
Z28SORR's Avatar
Re: Swap on Non Comp Controled Carb & Dist What do I do with ECM?
Don't know about the 86, but in 84 it just controlled the carb. and dist. I removed both the PCM and it's associated wiring.
Z28SORR is offline
Old 03-11-2013, 08:02 PM
BLACK Z !'s Avatar
What about the fan and the Gauges? I only have put about 1,000 Miles on teh car in teh last ten years, I'll manage with the gas. I'll pull the bulb.
Old 05-20-2013, 05:40 AM
BLACK Z !'s Avatar
Can I remove the sensors from the thermostat housing?
What are they for?
Does one control the Temp gauge? if so which one?
can I put it someone else?
I want to put a nicer one on there.
RUENUF
05-25-2016 08:10 PM
mr28
04-20-2016 05:44 PM
RUENUF
03-13-2016 03:39 PM
MadMav
05-25-2015 09:35 PM
mr28
11-23-2014 11:11 AM
Quick Reply: Swap on Non Comp Controled Carb & Dist What do I do with ECM?
