loose hatch?
loose hatch?
every time i hit a bump my hatch rattles (i know...not too shocking...)i finally took some time to look at it and if i close the hatch i can push on it and it moves up and down...is there a way to tighten the latch or anything so it doesnt rattle? thanks
The rubber stops will only help if the hatch is sitting low when it is shut. To make it line up with the quarter panels you will have to adjust the rubber bumpers and the latch. The latch is located behind the carpet and can be adjusted up and down by loosening the bolts that hold it.
