Leak from under dash
Old 08-29-2004, 06:40 PM
Black1996Z28's Avatar
Exclamation Leak from under dash
Yesterday i noticed that under the dash on the passenger side water was beginning to puddle up on the floor mat. After taking a closer look it seems as if the car is leaking from under the dash behind the center console. Does anyone know what this may be and has anyone encountered this before? Any and all help is appreciated.
Mike
Black1996Z28 is offline
Old 08-29-2004, 06:49 PM
Terran2k's Avatar
Re: Leak from under dash
seen this alot, usually its a leaking heater core
Terran2k is offline
Old 08-29-2004, 06:50 PM
RamAir95TA's Avatar
Mike
That's a definite indicator of a bad/leaky heater core.
RamAir95TA is offline
How would that be fixed? Or should i just take it to the shop?
Old 08-29-2004, 06:55 PM
Terran2k's Avatar
have some time on my hands, so i did a search (helpful feature by the way) and came up with this....
http://web.camaross.com/forums/showt...ce+heater+core
Terran2k is offline
Old 08-29-2004, 07:02 PM
Thanks for your help. Seeing a puddle on my floor kinda startled me last night. Would it still leak if i was driving without the AC on? Where can i get a new heater core also?
Old 08-29-2004, 07:36 PM
Two good possibilities. Heater core or the a/c condensate drain is clogged. Was it water or coolant that was puddling?
The heater core is still pressurized no matter if the heat or a/c is on, so if it has a leak, it's gonna leak. You should be able to get a core at most auto supply places.
shoebox is offline
Old 08-29-2004, 08:24 PM
It seemed just like water to me and my dad.
Old 08-29-2004, 10:56 PM
slayer6x6's Avatar
Sounds more like the evaporator drain is clogged. Im not sure what the heater box looks like on the f bodys, but Ive seen the water also get into the blower motor so be careful of that.
slayer6x6 is offline
Old 08-30-2004, 08:36 AM
stereomandan's Avatar
It's the evaporator hole that is plugged. I had this same problem this spring. If you look at the black plastic casing the under the hood where the AC lines enter the car, there is a hole underneath that. You can only see it from under the car. It's on the passenger side, near the firewall. It's hard to see. Get a flashlight and a long screwdriver and just poke into that hole. When I did this, all sorts of water started pouring out on me. It was clogged. I had water on my passenger floormat just like you before I cleaned out the hole. It's been great ever since.
Shoebox has a picture of it somewhere I think.
Dan
stereomandan is offline
Old 08-30-2004, 10:08 AM
Dan
Pic here
shoebox is offline
Solo2
01-01-2021 02:23 PM
Magenta_Hearts
03-29-2017 08:54 PM
Scorch1
06-30-2015 11:24 PM
06-19-2015 01:34 PM
Brake_L8
01-20-2015 09:44 AM
Quick Reply: Leak from under dash
