High Beams Work, Low's Don't
Old 06-08-2014, 05:59 AM
mccann18's Avatar
I'm having trouble with the headlights on my 95 Z/28. High beams work, but the low beams don't. I've read some of the posts and found the high beam switch near the steering column. We can move the connecting rod to turn off the high beams but we are left with nothing on. We replaced the lever on the steering column, no change. We went looking for a fuse but found the fuse slots are empty in the power distribution panel??? I don't know if that's normal.
I also don't know if the low beams are supposed to be on at the same time as the highs (in other words, does the high beam switch bring on the high beams in addition to the lows). I think my next step is to replace the lows beam headlights, only because its a little tight to get the leads of my meter back there. So, if I have to take it out to check, I should probably replace. Any help is appreciated!
mccann18 is offline
Old 06-08-2014, 09:54 AM
Re: High Beams Work, Low's Don't
If you don't have a copy of the headlight wiring diagram, go to shbox.com for a copy. Rob/Shoebox has a huge collection of LT1/4th Gen info. Much of it is based on his own 95 Z28. I'd post the direct link but I'm on a phone.
Injuneer is offline
Old 06-08-2014, 12:26 PM
mccann18's Avatar
Awesome site, thanks for the head's up! Found the schematic i needed, now I'm off to the races!
mccann18 is offline
Old 06-08-2014, 09:13 PM
Prominent Member
GaryDoug's Avatar
Location: Born on the Florida West Coast, now where can I retire?
On a Camaro the low beams are always on and the high beams are controlled by the dimmer switch. On a Firebird, both are controlled by the dimmer switch and only one set is on at a time.
GaryDoug is offline
AlaskaZ28
01-01-2015 12:30 PM
Jazsun
12-29-2014 12:14 PM
Catmaigne
12-25-2014 12:16 PM
siguy
11-27-2014 10:07 AM
Quick Reply: High Beams Work, Low's Don't
