help me identify these plugs in the engine harness
#17
do you know off hand where it would plug into?
Shoebox's car is an A4 so anything for a manual wouldn't be in that harness picture. except if i remember right i have a wire running up to the dash labeled rev light (i sent the harness into LT1 wiring to clean it up)
#18
If it dangles off the harness in the direction of the transmission, then it could be the reverse lights, skip shift, VSS...
Fred posted a picture somewhere the other day of the transmission and connections.
#21
ok, I eliminated EVAP as a possibility last night...it doesn't fit and I have both connections nailed down for EVAP. So it could maybe be reverse lights or crank position sensor. Can anyone tell me where either one of those connect? I do not see anything left on the engine or transmission to connect to so it must connect to something off the body harness?
Here is a better picture of the connection in question...its the one with the purple seal laying right next to the frame. the wire colors i think were two reds and a yellow.
and a bonus picture of the car in question
#22
First you ask about "either one".... then you seem to be limiting it to the single connector with the purple seal. If by "either one", are you including the 4-pin connector with the yellow seal? Looks like the passenger side pre-cat O2 sensor. The wire colors would be tan/purple/black/brown.
#23
#24
it's definately the crank pos sensor...i must have missed it tucked in under there on the timing cover. thanks everyone!
#25
#26
01-05-2015 07:14 PM
