Weird Problem...Maybe Someone Can Help?
Old 09-02-2013, 07:19 PM
Stephen68's Avatar
Hey everyone, i have a strange problem....a while back i told some of you that my IAC had not been plugged in since i had the car and they had even cut the plug off from the wires. well, i purchased a new plug end and wired it up properly according to shoebox's diagrams. i re set my ECU and stated the motor. for some reason the motor now has what seems like a little miss in it when its cold. i unplugged the IAC to see if this was the problem and the car now idles very high which it never did before i re attached the IAC. anyone have any ideas what could or would cause this?
Thanks...
Stephen68 is offline
Old 09-02-2013, 09:07 PM
Prominent Member
GaryDoug's Avatar
Location: Born on the Florida West Coast, now where can I retire?
Re: Weird Problem...Maybe Someone Can Help?
The IAC is a motor-operated air valve. It has evidently changed position while it was plugged in and now is farther open. I would plug it back in, let the engine warm up and set the idle to normal, then unplug it. I think it can be manually re-positioned, but that may damage it if not done carefully.
GaryDoug is offline
Old 09-02-2013, 09:53 PM
Stephen68's Avatar
Thanks GaryDoug, i think i might try to actually re set the sensor in the morning and see if that helps. it seems to run much better with the IAC plugged in, just idles a little rough when its cold...
Old 09-02-2013, 10:20 PM
Did you do the IAC reset procedure? If you unplug the IAC with the engine running, the PCM can lose track of where the position is supposed to be, possibly screwing up idle control.
shoebox is offline
Old 09-03-2013, 04:13 PM
Stephen68's Avatar
shoebox, i went back and performed the IAC reset according to your instructions and it worked perfectly....Many thanks buddy!...
Nayr
03-03-2023 08:34 PM
BigED
06-26-2015 10:58 PM
Zuvell
05-15-2015 08:18 PM
reww86
04-27-2015 05:17 PM
97z28k&N
01-09-2015 04:58 AM
Quick Reply: Weird Problem...Maybe Someone Can Help?
