Elitesparkplugs OTVC wires
Old 07-12-2005, 06:50 PM
Loading's Avatar
I just got my OTVC wires for my LT1. In all the pictures I've seen, people have 'brackets' on the valve covers that hold the wires.
Are those brackets supposed to come with the set, and if not, what are they called and where do you get them?
Thanks.
Loading is offline
Old 07-12-2005, 06:59 PM
blind527's Avatar
Re: Elitesparkplugs OTVC wires
They are called wire looms and they do NOT come with the set. Go to thunderracing.com and get some Made For You wire looms that fit your set. I advise if you got the 8mm wires get the 9mm looms, the 8mm will fit fine just a little tight. If you got the 9mm get the 10mm looms.
blind527 is offline
Old 07-12-2005, 07:12 PM
Loading's Avatar
Isn't that just great. I can understand 10 dollars, but 63 dollars is just silly. If I'd known I needed these, I would have definatly just gone with normal wires.
Loading is offline
Old 07-12-2005, 07:14 PM
blind527's Avatar
OTVC wires are a great investment. The Elitesparkplugs.com wires with the 1200* heat protection are the best wires I have EVER used. My headers can sit right on the wire and I would have NO problems. Make sure you get the right looms, they are easy to install, but also these are a GREAT investment!
blind527 is offline
surreybrad
04-22-2015 06:40 AM
EdgarArmada
04-18-2015 05:20 PM
Brandon Wittmer
12-03-2014 09:28 PM
Ryabut98
09-03-2002 11:45 PM
kandied91z
08-06-2002 01:18 AM
Quick Reply: Elitesparkplugs OTVC wires
