Are the metal replacement headlight motor gears still around?
Old 08-21-2013, 07:13 PM
Laymaster's Avatar
I remember I replaced one a long long time ago in a galaxy far, far away. Are these things still available or is the best bet to get a new headlight motor these days?
Laymaster is offline
Old 08-21-2013, 10:22 PM
Prominent Member
GaryDoug's Avatar
Location: Born on the Florida West Coast, now where can I retire?
Re: Are the metal replacement headlight motor gears still around?
Yes, they are. I recommend the ones from Rodney Dickman because they are the type that uses the rubber cushion in the gear. Also his gears include the cushion and a special T-brace to keep the box cover in place if (or when) the glue fails.
http://rodneydickman.com/catalog/pro...roducts_id=151
Also available in aluminum.
GaryDoug is offline
Old 08-22-2013, 12:01 PM
siguy's Avatar
Yes look them up on eBay cheap and easy to do .. Did both my motors years ago never had a problem again.. 99.99% never wears out its always the plastic gear that wears out ...
siguy is offline
Old 08-22-2013, 03:08 PM
Laymaster's Avatar
Sig,
The motor works no problem. Just have that grinding noise plus the headlight pops up when I turn on the parking lights. I replaced my passenger side years ago with the brass gear.
Did you replace your entire headlight motor instead of the gear?
LeftoverChinese
01-14-2024 03:03 PM
10-31-2016 11:09 AM
CaRParts102
12-06-2014 08:45 AM
1LEThumper
07-14-2003 12:45 PM
97 RedSS
06-10-2003 07:58 PM
Quick Reply: Are the metal replacement headlight motor gears still around?
