Carpet Soaked After Heavy Rain - Why?
Old 10-21-2011, 07:38 AM
1quickTA's Avatar
I noticed that the carpet in the rear driver side footwell was SOAKED. I noticed that the water was dripping pretty good from the seam between the rear of the driver side t-top and the plastic trim panel it meets.
Any ideas why this is leaking?
While looking around, I also noticed that the front passenger footwell is SOAKED too. What the hell is going on with my car?!?!? I have no idea where this one is coming from. Any idea? I didn't notice any leaking. Perhaps from the grommet in the firewall? Mine is in bad condition from sending other wires through it, but I have never had a problem.
Do you think I should pull the carpet or will it be fine if I just shop vac it out?
1quickTA is offline
Old 10-21-2011, 08:05 AM
Procharged94Lt1's Avatar
Re: Carpet Soaked After Heavy Rain - Why?
The pad is going to be soaked as well- shop vac will take a lot of it out, but likely not quite all of it.
As far as the leaks, check the firewall- there have been posts before about guys finding grommets missing and then finding rusted footwells below the carpet.
I would definitely at least pull the carpet back to see what it looks like underneath.
Procharged94Lt1 is offline
Old 10-22-2011, 12:58 PM
96 Z 28's Avatar
Do a search, but the jist of it is the water comes in fromt he rear hatch and leaks down from behind the rear seat.....
96 Z 28 is offline
Old 10-22-2011, 04:04 PM
jproz1167's Avatar
My 97 sometimes does this in heavy rains if I park the car downhill and the rain floods the hatch areas where the weatherstripping is. when parked uphill the rain drains out of those areas though. So that is the easiest fix just park uphill during heavy rains.
jproz1167 is offline
Old 10-22-2011, 07:39 PM
DeuceGI's Avatar
I've had this happen as well. Ended up removing the entire interior to get the carpet to dry properly.
DeuceGI is offline
Old 10-28-2011, 02:46 PM
brettmc's Avatar
sounds like your t-tops are leaking. check the t-top drain holes. I bet they are plugged up.
brettmc is offline
93 RedBird
11-15-2015 08:24 AM
9t4lt4z28
10-02-2015 10:28 AM
Daluchman1974
09-11-2015 06:12 AM
damnyankee36
09-09-2015 07:06 PM
Quick Reply: Carpet Soaked After Heavy Rain - Why?
