Can anyone tell me what this part is named Or the part #?
Old 04-11-2014, 08:28 AM
lonewulf's Avatar
Sorry if this should go somewhere else, it's not really tech, but I didn't think it really fit in the appearance section
It's the bolt/hook thing in the rear hatch/trunk area of a 98-02 Trans Am. I believe they are supposed to be for securing a child car seat or something.
Mine stripped like a beeyotch and I cannot find it on GM parts direct or Rock Auto. Thank you very much in advance for any assistance!
lonewulf is offline
Old 04-11-2014, 08:53 AM
Re: Can anyone tell me what this part is named Or the part #?
Are you sure that is a factory part? I don't see it listed in the parts book.
shoebox is offline
Old 04-11-2014, 09:20 AM
lonewulf's Avatar
Yes, there is one on each side of the flat rear hatch area, right behind the back seats. My car is a 2001 WS6.
lonewulf is offline
Old 04-11-2014, 09:37 AM
I have the 2000 shop manual. I'll take a look and see if it is covered there. I have never seen those in a 4th Gen F-Body.
Injuneer is offline
Old 04-11-2014, 09:48 AM
lonewulf's Avatar
Looking at my owners manual, in Section 1 (seats & restraint system) it refers to them as "strap anchors"
lonewulf is offline
Old 04-11-2014, 09:51 AM
Is it the bolt that is stripped, or the threads in the sheet metal the bolt goes into?
Checking the 2000 manual, these appear to be dealer installed. The manual has an "Initial Installation" procedure. The deck has a threaded reinforcement plate under the sheet metal, from the factory. Bolt gets tightened to 31 lb-ft. The actual anchor bracket appears to have been part of a "Child Seat Restraint System Belt Kit".
Injuneer is offline
Old 04-11-2014, 10:03 AM
lonewulf's Avatar
Nope the bolt head is stripped to hell. Plus, I'm an idiot and I managed to break off the tip of a drill bit in it trying to drill it out. It's a star head, rather than a Phillips or flat screw driver head, and it's not a hex head, it's round.
Apparently it's referred to as a strap anchor or cargo hook. No idea what the part number is, but there are several on eBay now that I have the name(s).
lonewulf is offline
Old 04-11-2014, 10:25 AM
Torx fastener
Injuneer is offline
Old 04-11-2014, 09:15 PM
Prominent Member
GaryDoug's Avatar
Location: Born on the Florida West Coast, now where can I retire?
Here is what I would try: Get a small cutting wheel bit for that drill and cut a big slot in the head of the bolt. Then use a big a** screwdriver in the slot. If that doesn't work, use a cold chisel to knock off the bolt head (or a grinding stone bit to grind it off) and remove the rest of the bolt with a pair of locking pliers. Good luck.
GaryDoug is offline
BIGCOWL-IMP
12-19-2014 06:59 AM
12-01-2014 08:08 AM
ChrisFrez
11-23-2014 10:33 AM
dreamer1q
01-31-2008 07:03 PM
Quick Reply: Can anyone tell me what this part is named Or the part #?
