94 Camaro A.I.R. Delete
Old 11-29-2009, 11:14 PM
ekotarba's Avatar
i have a 94 Camaro and i need to find out if it is safe to remove the A.I.R. but leave the EGR hooked up. I know that this will throw a code for the AIR.
ekotarba is offline
Old 11-30-2009, 05:13 AM
Your OBD-I PCM (93-95) will not set a code for removing the AIR system. You just need to make sure there is a good fuse and relay in the AIR pump circuit. AIR and EGR have nothing to do with each other. AIR runs only at startup to help the catalytic converter(s) heat up faster. EGR is used under cruise conditions to reduce the formation of NOx (oxides of nitrogen). The systems do not interface on the 94-97 LT1's. Only on the 93 did they share some common piping.
There is nothing unsafe in removing AIR. It just means your cat, if you still have it, will take longer to heat up and start working. You have to block off the point on the intake ducting where the hose connects to supply filtered air to the AIR pump, and you have to plug the holes in the manifolds (or headers if they have AIR connections).
There is no performance gain, just a minor weight loss.
Injuneer is offline
Old 02-13-2017, 07:27 PM
Alec29's Avatar
Re: 94 Camaro A.I.R. Delete
when u take off the A.I.R do u unplug the coilf sensor or whatever its called and also unplug the temp sensor, its the one that unplugs from the air pump thats pinkish purple then the one right above the air pump thats blue, i have pictures for it i was just curious if u leave them unplugged
Alec29 is offline
Old 02-14-2017, 12:37 AM
What year is your car? AIR has a few year-to-year variations. If you have a 95-97, do you know if the "AIR recall" was done on it? If you have a 96-97, the above procedure will not work. There are other diagnostics added in OBD-2 that actually check to see if there is air flow into the exhaust manifolds.
https://www.camaroz28.com/forums/lt1...nature-879835/
http://shbox.com/1/air_pump_recall.jpg
If you have picture of the coil and temp sensor, please post it, because that does not sound familiar. The OBD-1 years have a 3-pin connector to the AIR pump, with two red wires and a black wire.
Wiring diagram - OBD-1 (see top of page):
http://shbox.com/1/1995_pcm4.jpg
Injuneer is offline
Old 03-26-2017, 03:13 PM
Alec29's Avatar
For some reason i cant post a picture of it im on my phone dont know how but i will try, but ik to the air pump theres the purple connector i undid then the blue one, my car is a 95 z28
Alec29 is offline
DropZ
01-15-2015 10:40 AM
cmdeshon
12-27-2014 10:06 AM
07-04-2005 05:00 PM
Quick Reply: 94 Camaro A.I.R. Delete
