94 camaro can you jump ac compressor to kick it on
Old 05-20-2014, 01:46 PM
Brandon Wittmer's Avatar
Got a 94 camaro z28 tring to get some ac going I know I gotta vac it replaced the dryer and o rings now I wanna make sure the compressor will even kick on before I throw 60 bucks in Freon at it is there anyway to jump it to get it to kick on for a split second
Brandon Wittmer is offline
Old 05-22-2014, 07:41 PM
Cam's maro's Avatar
Re: 94 camaro can you jump ac compressor to kick it on
I remember my dad had a 81 Chevy pickup. He used to unplug the compressor pressure switch and jump across the terminals with a piece of wire with crimped spade tips. I don't remember exactly how he did it but it was a pressure switch and it would run for sure. Maybe someone who reads this will be able to elaborate on it more for you, but it can be done
Cam's maro is offline
Old 05-22-2014, 08:01 PM
rngilliland's Avatar
Pull the PCM fuse or unhook the battery for a few seconds. That will clear any a/c codes and allow the compressor to run. Most of the first can will go in just from the vacuum and there will be enough pressure to keep the compressor running. Three twelve ounce cans works good for an empty system. You may want to add some oil too.
rngilliland is offline
Old 05-23-2014, 09:20 PM
thanks everyone i got it running and its cooling very well now! thank god
alphaauto
01-23-2015 07:42 AM
njspder
Middle Atlantic
01-08-2015 11:13 AM
12-01-2014 08:08 AM
BIGCOWL-IMP
11-21-2014 09:40 AM
Snoman73
11-17-2014 07:22 PM
Quick Reply: 94 camaro can you jump ac compressor to kick it on
