2000 camaro electronic lock will lock but not unlock
Old 11-19-2013, 01:39 PM
buzzsaw's Avatar
The passenger side of the 2000 Camaro will lock but not unlock only with that switch - works fine (lock/unlock) from driver's side and remote.
Ideas and directions? TIA !
buzzsaw is offline
Old 11-19-2013, 08:27 PM
Prominent Member
GaryDoug's Avatar
Location: Born on the Florida West Coast, now where can I retire?
Re: 2000 camaro electronic lock will lock but not unlock
I can't imagine the problem being anything other than a defective switch.
GaryDoug is offline
Old 11-20-2013, 04:48 AM
eanhl2004's Avatar
Yeah if the remote works unlocking the door then the mechanism/motor works fine.. take the passenger side switch out. check for corrosion or any thing that would weaken the signal..check wiring if possible... if everything looks okay then go buy a replacement switch.. they cost less than $25 last I knew... I think they are side specific... I've replaced mine.. it's easy to do
look up shoebox's door regulator replacement guide as I believe it's basically part of it.. if not just look at the door.. whatever it was it was easy.. think it might be just clips holding it in.
eanhl2004 is offline
Old 11-21-2013, 07:57 AM
Prominent Member
GaryDoug's Avatar
There are just clips holding down the switch panel in the door. You pry it up and out of the door armrest/handle; but since it is made of plastic, you have to pry carefully to avoid breaking it. Make sure the connector hasn't just worked part way off the switch, because that could cause your problem also.
GaryDoug is offline
Old 11-24-2013, 01:04 PM
buzzsaw's Avatar
Are you suggesting I can pop the switch off of the door without removing the panel ?
buzzsaw is offline
Alien
West South Central
01-11-2015 12:51 PM
ro2207
12-04-2014 06:18 PM
5.7L 00 SS
08-06-2002 07:01 AM
Mad_Ice
07-29-2002 09:44 PM
2000silverz28
07-20-2002 06:14 AM
Quick Reply: 2000 camaro electronic lock will lock but not unlock
