1995 Paint code help
I need to buy some touch up paint for my 95 Z28. However, the space after the BC/CC on my glove box sticker is blank. There is a number for the upper body color U9806, but no number for the lower body color - the space is blank. The color on the car is a dark green. Can anyone supply the paint code for that color? (hopefully there were not two greens for that year).
Re: 1995 Paint code help
Polo Green Metallic - Code 48. The same color on the Firebirds was called "Dark Green Metallic" with the same code. If you get a small tube of touchup from GM, is will be labeled "Yellow-Green Metallic".
Thank you so much for your help. I saw that code on touch up paint at O'Reilly's today, but not called Polo Green. I suppose they used that color a number of years. They called it Polo Green on my '95 Corvette as well, althought it did appear darker, but my memory may not be serving me well. Thanks again.
07-04-2005 05:00 PM
