1974 Z28 ???'s
Old 02-19-2010, 07:39 PM
dickeymoore's Avatar
1974 Z28 ???'s
Did Chevy make a 1974 Z28/Type LT camaro?There is a guy that says his is a Z28/Type LT and it is for sale,four speed with 350 engine(non matching numbers engine and trans) and he wants $6000 for it is this a GOOD deal?Thanks
dickeymoore is offline
Old 02-19-2010, 08:12 PM
96capricemgr's Avatar
In the early 70s they made an LT-1 motor the "-" being the important part there.
It was a solid flat tappet cammed 350 factory option.
That helpful or did he mean as a option package like "Z28"?
Oh and I looked it up, the LT-1 was available 70-72 and to be clear was just a carburetor gen 1 motor. They recycled the name LT1 for the Gen 2 V8 developed in the early 90s.
96capricemgr is offline
Old 02-19-2010, 08:27 PM
Like an optional package like Z28.Thanks
Old 02-19-2010, 08:32 PM
rngilliland's Avatar
The type LT refers to the trim package. I don't remember exactly what it included but it was the higher trim with cloth seat, power windows etc. The engine in all Z28s was the L-82, 245hp, 350ci, quadrajet carburetor. The Z28 was available in the LT trim.
rngilliland is offline
Old 02-20-2010, 09:37 AM
The Camaro White Book indicates that in 1974 the Z28 option was available on the Type LT, at a cost of $502.05.
Type LT was introduced in 1973 as a distinct model, to replace the Super Sport option. The Type LT could be ordered with the Z28 option, the RS option, or both. RS was dropped on 1974.
Injuneer is offline
Old 02-21-2010, 09:51 AM
twozs's Avatar
1974 Type LT - Plusher Interior with restyled seats and door trim in cord-ridge fabric or knit vinyl, new woodgrain treatments, color coordinated instrument panel, steering wheel and column. Amberlite insulation blankets included in doors, rear quarters, roof/sail panels, behind rear seat, under package tray and under carpeting. Type LT could be ordered with RPO Z28............................................... .................................................. .Z28 Verification: The 5th digit of the VIN will read "T". Period.
Total Production: 13,802
Engine: Includes special 350 CID, 245 hp V8. Four-bolt main bearing caps, forged steel crank, impact extruded aluminum pistons, heat treated & shot peened connecting rods "big valve" cylinder heads with high speed valve train. Cast aluminum rocker covers with internal galleries. Hydraulic lifters cam & cast iron intake with EGR. Rochester Quadrajet. 17-quart cooling system with 18" 7 blade flex fan. Oil pan windage tray and high speed crankshaft damper. Dual Exhaust pipe system. Same setup as 1973, HEI (high-energy ignition) introduced in mid-year (January 74). Special dual snorkle air cleaner with chrome lid.
Click here to see the specific L-82 Engine Components.
1974 Z28 Carburetor (Rochester Quadrajet 4MV) - A/T - 7044208 , 4 spd - 7044209
Transmission: Weight saving aluminum gear cases for all 4-speed transmissions. Increased shift-points for Turbo-hydramatic (TH400) transmission.
Clutch : 11 inch clutch. Same as 1973.
Rear Axle : Ratios were 3.42 for Turbo Hydra-Matic and 3.73 for 4-speed; Positraction standard. No options. (Identical to 1973.)
Brakes: 11-inch, vented, cast-iron front discs with vacuum assist standard. Rear 9.5-inch drums. (unchanged since 1970)
Front Suspension: Spring rate: 300 lb./in. Front stabilizer bar 0.938 inch. Unchanged from 1973.
Rear Suspension: Spring rate: 89-99 lb./in. Rear stabilizer bar 0.69 inch. Unchanged from 1973.
Steering: Power steering standard in all Z-28's, with 14.3:1 ratio (same as in 1971 but with more road feel.)
Wheels & Tires: 15 x 7 steel wheels (trans-am) with bright lugnuts, special center caps and trim rings, F60-15 fiberglass-belted white letter tires standard. (Unchanged since 1970)
Click here to see the specific 1974 Z28 Chassis Specifications.
Other Options, equipment, facts: New, big, 4-color hood and deck decals (RPO D88) optional. When D88 is specified "Z28" fender emblems are deleted. There's conflicting information on where and when Z28 emblems are used when Type LT is ordered and/or special D88 striping is used. Z28 foil decal on rear end panel. Dual Sport mirrors (RPO D35) standard. Black-painted grille with bright argent outline. RPO Z28 dropped at the end of model year. Suspension (spring rates) on the Z28 seem to be identical to RPO F41, rear shock valving is different. Z28 gets 15 inch wheels, different alignment specs (vs. base) and quicker steering (vs. base) Available on Type LT model.
twozs is offline
Old 02-25-2010, 04:32 PM
GhostZ28's Avatar
if its a solid car i'd say yeah, but I'm one of the few that LOVES the 2nd gens
GhostZ28 is offline
Old 02-25-2010, 06:32 PM
Here is the 1974 Z28/Type LT[IMG]z28[/IMG]
Old 02-25-2010, 06:37 PM
Angelis83LT's Avatar
LT type is the same designation they used for the Berlinettas. I would guess it is the same option platform. So, it was a Z28 with "berlinetta" options.
Angelis83LT is offline
Old 02-25-2010, 10:30 PM
Adam96Z's Avatar
I'd say it is a good deal if the car is rust free. I was looking for a second gen last spring and could not find a decent one that was rust free for under $8k.
About 10 years ago I picked up a 75 TA for $4200 that was in pretty decent condition. I'd love to find one for the same price now that wasn't a complete pile.
Adam96Z is offline
Old 02-27-2010, 06:21 PM
Got the 74 Z28 only has slight rust in the trunk.
F'n1996Z28SS
08-23-2023 11:19 PM
Renegade Toker
01-23-2015 10:27 PM
NewsBot
01-11-2015 06:10 PM
01-05-2015 07:14 PM
cmdeshon
01-04-2015 11:15 AM
Quick Reply: 1974 Z28 ???'s
